A three story residential apartment building with 80 units and underfloor garage is proposed to be wired with SER cable. The Electrical room and meters are in the garage level.The SER cable will go from the garage enclosed in a sheetrock chase up against the underside of the garage ceiling and up via shaft.
1. Do I have to derate the ampacity of the SER cable since the 80 SER cables will be stacked or bundled without spacing in the shaft.
2. Is permitted by Code the use of chases with sheet rock.
3. The Code defines SE Cable, is SER cable the same.
