johnjustjohn
- New York
I've asked this question of several licensed electricians and none of them agree on an answer. To upgrade the service on my house the panelboard will be located about 30 feet from where the service entry cable enters a crawl space. I understand that I'll need an outside disconnect, SEU outside and SER inside. All agree. 2/0 copper will be used as is standard here on Long Island. Two of the electricians I've spoken to say that for the inside run, conduit isn't necessary. One says it's a good idea.
I've decided that since I'm the one crawling around under the house working on things that I'd like the SER inside a conduit, say PVC Schedule 80. My question is this: Do I need to consider heat build up inside the conduit? Can I just ask my electrician to put the 2/0 SER inside 2' PVC? What section of the NEC talks about this?
I like to know as much as possible about a job, especially when I need to hire someone to do it.
Thanks,
John
Thanks,
John
