patrickcronin
- Davidson, NC, USA
I am transitioning 4/0, 4/0, 4/0, 2/0 AL from SER cable in a crawlspace to the same sized USE cable at the exterior for 200A service to an auxiliary building.
I plan to make the junction outside of the home in a NM junction box.
My questions:
1. Does the SER cable need to come out of the crawlspace in an LB to enter the junction box from the side (assumes an 18" x 18" x 6" box) to accommodate the radius requirements?
2. If so, what size LB is sufficient for this size cable?
3. Or, can the SER cable enter the box from the rear (6" depth)?
The real question is what is the best, safest method to make this splice?
I am thinking that keeping the splice on the exterior of the building would be better than a splice in the crawlspace but again, that's merely an assumption.
Thank you all in advance for your insight on this issue,
Pat
My questions:
Pat
