SER weatherproof connector
Pat75
Maryland
Just curious what everyone is using for SER w/p connectors? Supply house has seu w/p but not ser w/p. Hard to get ser in to an oval piece of rubber! Thanks in advance everyone!
Whatever you use it will need to be listed for the cable. Don't tell anyone but one time in a pinch once I filled one around the rubber seal with silicone and capped it with duct seal.
Those d**n WP SEU connectors are a joke.
Do the job in conduit and give the customer a set up that will last years without water intrusion
Decided to use a drill press and hole saw. Had coworker hold the bushing with channel locks. Worked perfectly!
