Pepito Santos
- Okinawa, Japan
In most diagrams of airfield lighting using constant current (series circuit) it show the wiring in a loop where the outgoing and return cables are in separate conduits. Is this not causing problem due to inductance? I saw an incident in a 208V safety switch in which the electrician passed the conductors in separate knockouts and the switch vibrated. We will be installing new edge lights in a taxiway and planning to run (loop) a single wire around the taxiway and would like to avoid any problem on the system.
