Series combination system and Available Fault Current signage - PV System Required?
inspector23
Temecula, CA
Not sure if this should be a PV topic or Electrical calcs, but I am only posting here.
I have a PV system being installed for a large retail store. it is a line side tap being installed on a 3000 amp, 480 V system. Since it is a line side tap and there are no other loads, only the 26 utility interactive inverters, my thinking is there is no need for either the series combination signage requirements of 2011 NEC 110.22(c) or available Fault current field marking of 110.24 (A) or (B). But obviously I am not sure. Any help/insight would be appreciated.
Thanks -
Me also looking forward solution in this regard. One of my friend "Steve" currently work in Melbourne(Knows as the name of "Signage Melbourne"), he is professional signage solution provider. He can help us in this regard. I will next time post complete system work regarding it. Sure this will helpful for you in this regard.
MO, it being a line side tap I don't see where a series rating sticker would be applicable but fault current identification would still be needed.
