Assume all examples below are using equipment from the same manufacturer (panels, breakers, busses, etc). Assume short fault is 35k at all locations. Typically from the manufacturers I seen, square d, Cutler, Siemens. 22kaic branch breakers are usually series rated with 65kaic breakers or in some cases even higher. But some senarios makes me question that.
Example 1: if the panel main circuit breaker is rated 65kaic but the panel itself is rated 22kaic and branch breakers are rated 22kaic. Would this be considerd a series rating?
Example 2: enclosed circuit breaker rated 65kaic, feeding a main lugs only panel rated 22kaic with 22kaic branch breaker. Would this be considerd a series rating?
Thank you
Thank you
