D.MOON
New member
- HUNTSVILLE, AL.
CAN CURRENT LIMITING FUSES BE USED AT THE PRIMARY SERVICE ENTRY FOR THE PURPOSE OF LIMITING FAULT CURRENT TO A LEVEL LESS THAN THE EXISTING FACILITIES EQUIPMENT'S AIC RATING, THEREBY REDERING WHAT WOULD OTHERWISE BE OVERDUTIED EQUIPMENT IN COMPLIANCE? IF THIS IS TRUE WOULD THERE BE A CONFLICT WITH 240.86 (B) OF THE NEC? IN OTHER WORDS WOULD THIS BE CONSIDERED AN ATTEMPT TO SERIES RATE PROTECTIVE DEVICES?
