If an MCC has 22KAIC bracing, but the available fault current at the line terminals is higher, can a current limiting fuse / breaker be used to protect the bussing?
In the case of overcurrent protection devices, I know that the upstream/downstream devices have to be listed as a series system. Is there a similar listing required when protecting downstream busbars?
