K8MHZ
- Electrician
I saw this yesterday in my doctor's examining room.
This is at receptacle level, about 20 inches off the floor. Because of the ground being up, the device is upside down. It can't be read or operated unless the person trying gets down on the floor and looks upside down at it.
This device is a mini UPS intended to keep small loads operational for the few seconds it takes for the generator to come on when power to the building is lost. This provides for a seamless transfer and one is on EVERY computer and LAN device in the building.
I have one of the infamous Kil-a-watt meters. It, too, would be upside down if used in a receptacle with the ground 'up'.
I have several emergency LED night lights. Not only do they have controls that would be upside down, but the when the power drops, the back up LEDs would be pointing the wrong way if mounted in a 'ground up' receptacle.
All my little plug in receptacle testers are oriented to be read from a 'ground down' receptacle. Some have all the light codes on the top, making them impossible to read in a 'ground up' receptacle.
I think, now that we are seeing a proliferation of receptacle mounted devices that have read outs and controls, we have transcended from 'it doesn't matter' to a point of having to seriously consider the ramifications of mounting receptacles with the ground on the top.
The cat has already been let out of the manufacturer's bag and they have set somewhat of a standard for receptacle orientation, and that is having the ground 'down'. I have never seen any receptacle mounted device or tester with a ground that was made to be used with the ground on the top.
We, the folks on the installation end of things, dropped the ball and because of our lack of setting an installation standard, many receptacles, especially in health care facilities, will render receptacle mounted devices very difficult to use.
A note to the moderators:
I know that this subject has been taboo here for years. I am not trying to start a debate and this certainly is not a troll. The operation of the UPS in my picture is crucial and failure to be able to read the display and operate the controls may cause loss of important patient information. Thus, yesterday's discovery on my part brings an entirely new light on the 'debate' due to devices that have only been present in proliferation for a few years.
The purpose of this thread is to inform people that the orientation of the devices are not compatible to the orientation of the receptacles when mounted with the ground up. Customers requesting 'ground up' orientation should at least be informed of the orientation standard set by the device manufacturers.
I also think that designers need to consider what they are designing and where it will be used. The only place I have seen the mini UPS devices have been in health care facilities, all mounted upside down. Devices that are likely to be used in health care facilities should be offered with both orientations, IMHO.
