I have some refrigeration equipment to reserve through a new sub panel that will be fed with utility as well as a back up generator. This complex is existing and somewhat old so there has been some bad wiring over the years. There are a few ice machines that may need OC protection that currently only plug into an outlet; while this may be okay I need to verify this before installing.
I need to calculate the existing equipment as well as some new, correctly, and re-feed the replaced sub panel with new. Article 430 address? motors:
My question is, were do I find direction to feed/serve refrigeration equipment correctly?
[ April 19, 2003, 03:24 PM: Message edited by: darren ]
