As long as each is sized correctly, and connected properly with a mixed-metal method, yes.Can copper be installed for the service then aluminum for feeders? Or does it have to be either or .
There isn't going to be a code reference for that. The code tells you what you have to do and what you can't do. It does occasionally tell you what you can do for clarification, but that is not its purpose. A question I would like to ask you to challenge yourself with is, what code references are leading you to ask that question? Note what Dennis said "no code against it"Thanks for the input do you know what code reference thats is?
