I am working on a project that provides a 480V, 3 phase, 4 wire service for a sewage pump station. We are providing the pump station with a manual transfer switch that will allow for connection to a portable trailer mounted generator. The manual transfer switch is a 4 pole switch fed from a service disconnect switch. The pump station load is connected to the transfer switch. Can we bond the grounding conductor to the neutral in the transfer switch if it is not service entrance rated? Otherwise it appears we will have to provide a separate generator disconnect switch to obtain the required neutral to ground bonding.
