Hey all so I was called out to a service call today for a dead circuit. So I find a tripped breaker an try to re set it and see a dead short . While doing so I saw an arc in a splice box so I opened it up fixed what I thought was the problem. It was BX into a 1900 coming out of the box was emt. So I tried to reset breaker and see an arc in a different spot. Them emt was leaning against a steam pipe and at the point there seemed to be some metal/arcing/welding lol. It seemed to me that it was looking for a ground. Arcing at several different locations. I reset breaker one more time to it held . The. I saw smoke coming out of the main disconnect it was a blown fuse . My initial thought was no ground to the building. Just a note its an old service fpe breakers no ground rod only a water main I think that the main ground to water main is most likely carroaded. Wat do you all think?
Sent from my SM-G935P using Tapatalk
