Do you usually leave the old main and riser on the house and just mount the new one next to it?I saw one service change where they did this.There was the old riser and weather head sticking out the roof and there was the new one next to it.When you give a estimate for this type of job do you include removing the old equipment or is it a extra charge.
if the old service riser is sufficient to hold the new feeders, i've cut
the old can out, and slid the new one in under it, but it's rare for
that to be possible. i've only done it twice in 30 years. obviously,
nothing lines up well enough for that to work well, if at all.
i had one old house in torrance i had to put a new service on, and
the original was 40 amp fuse type. the service entrance was a 1"
rigid down the eave to the back of the house, where the new
service was going.... i set a new service on the back of the house,
surface mount, with the riser up thru the eaves. after edison heated up
the new panel and killed the old one, i pulled out the service entrance
conductors from the 1" rigid, piped it into the new panel, and pulled
the branch circuits from the new panel to the old panel to feed the
existing wiring. then i gutted the old panel, set a terminal strip, and
landed the six circuits for the existing wiring.... then had my sheet
metal guy bend up a piece of #14 stainless for a nice cover for the
old can, so it was just a smooth surface, and looked tidy.
so if you can incorporate it for a clean look, that's one thing.
if it's there cause someone was too lazy to finish the job, that's
quite another.......
