hi i'm a ec from the state of washington and have a few question,i know most of these answers just double checking. ( don't want to look like an idiot in front of the client when the inspector red flags the job.
1 service entrance cable can only go 15' inside the house, is this from the meter base or from the point it enters the house.
2 cables from meter base to panel has to be SE cable cannot be thhn, etc.
3 if i install a combo meter with a 200 amp disconnect this would be consided the service and the panel in the house would be a sub panel, and i could fed this with thhn type wire.
also i would drive ground rods at combo meter and bring the egc to the sub panel, would i also have to drive ground rods at the panel?(its in a basement concrete floor)
4 the panel will be surface mount on a concrete wall (no wood framing or sheetrock)open ceiling about 7'high, can i leave the romex entering the panel exposed or run pvc to floor joists ( about 6")
5 i know that what i work on i have to bring up to code, but on a service change where do you draw the line. i believe i need to install arc fault breakers on the bedroom circuits, but how about circuits that weren't required 25 years ago, or a hot tub that doesn't have a gfci breaker, or kitchen and bathroom plugs with no gfci protection,or other violations.is the inspector going to make me bring the whole house up to code before the power is turned back on. what should be included in the price and what should be charged as a extra.
thanks for your input and have a great new year
