I am considering doing a service change on my house. The only problem is that the PG&E drop is about 20' away from my dog house which lies inside my stucco wall. My question is can you run a 2" I assume Rigid pipe on the inside of my garage up high, 90 out of my panel add 20' and 90 out the top of the roof to where I will be able to tie into PG&E?
I cant go undergound and I can't surface mount a panel under the drop because it will be mounted right in front of my house for the entire neighborhood to see!
Any help would be appreciated, I tried looking it up in the codebook but couldn't find it.
Thanks
Thanks
