If you were install a 320 meter main service with the plan of only using the 1 supplied 200 amp breaker to feed the portion of the building that will be currently wired up do you see anything wrong, code wise, with sizing the service conductors for the planned load that will be fed?
In other words, a customer has a building that they only want one area to be wired up, with the idea that, maybe, a few years down the road they would have the other portion of the building done. At that time an additional 200 amp breaker would be installed to feed a panel in that portion of the building. Then, the service conductors would have to be up sized to feed that additional load.
Under ideal condition, at the start of the project, the service conductors would be sized to feed the whole building, 2-200amp panels. But this person doesn't have the money to do more than just the bare minimum for the initial part of the building. The plan to size the conductors for one 200 amp panel is just to get the project off the ground.
I don't see any problem, code wise, with installing the service conductors for the one 200 amp panel...
Any feedback would be appreciated,
Thanks!
Thanks!
