- Tennessee NEC:2017
- Semi-Retired Electrician
I think I know the answer to my question but for some reason I'm not 100% certain, must be a "senior moment".:happysad:
Had a guy call about some work and part of it involved running power to a separate building. I haven't gone to look yet so I'm just going on what he told me.
He says he has a 400A service to a building and is only supplying a 200A panel to that building. He says the meter is a dual lug but I don't know if it's a 320A or true 400A. I also don't know if it's a commercial/industrial building or residential.
Anyway, he wants to power another 200A panel in a separate building from the other set of lugs in the meter base.
Question is, can the other building be supplied from the meter without a disconnect, and does it matter whether it's residential or commercial/industrial? Also, does it matter as far as whether the meter base is 320 or 400A?
Thanks!
Thanks!
