service demand load
a store with outside demensions 50ft by 160 ft supplied by a 208y/120 volt 3 phase 4 wire with the following equipment
2 split system hvac consisting of 2-5 ton ac condensing units with a rated load current of 31 amperes each
2-1 hp air handling unit containing a 10 kw duct heater (all equipment is rated 208 volt 3-phase)
1-5kw water heater (3-phase)
1-5 hp trash compacter (3-phase)
3-12 foot show windows
1-1500 va sign
70-duplex receptacles (120 volts)
What is the total calculated demand load for this service?
What did you come up with and how did you come up with your answer?
Roger
