dvcraven0522
- St. Louis, Missouri
- Engineer
I have an existing utility meter and CT Enclosure that I need to add a building service disconnect to. If the disconnect is mounted on the outside of the building is there a code restriction as to the maximum distance the disconnect must be installed.
Thank You
Dan
Thank You
Dan
