bpk
- Northern Minnesota
I will be doing a residential service upgrade from 100 amp to 200 amp. The house is older and the original service entrance conductors are now entering the house into the utility room in the basement under a poured concrete slab.
The homeowner wants only minimal conduit on the outside of the house. The meter base is on a pole about 60 feet from the house. My question is can I put a 200 amp disconnect on the pole,trench as close as I can get to the utility room and then enter the house with conduit and run through the basement to the panel location, or will the disconnect need to be on the house. Accorrding to 230-70(A)(1) it seems like it should be ok but I have a feeling that if I did it the inspector would say something, is there any other code article that would prohibit this
