hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch shows on left side solar panel disco tapped from the line side of main service disco. On the right sketch show non solar panel install main service fused disconnect which feed downstream panelboard.
On the left solar disconnect one can switch it to off by pressing handle position then easily open the disconnect enclosure exposing line side live conductors. Same for the right side fused service disconnect and someone other than qualified person perhaps kids can be exposed to live conductors if they are installed outside attached to building outside wall.
Question to avoid above is their anything in NEC 2014 that such type of disconnect to be locked shut and one would need tool to open to them? If yes then which NEC 2014 code section? If not in NEC 2014 then anyone anyware of any such amendment to the NEC 2014?
