I have a 1200A existing unmetered main disconnect on the exterior of a building with a gutter can and (3) small services. Owner is building out new units on the far end of the building. We added a 800A ECB directly next to the 1200 and paralleled (3) 3" conduit to a new gutter on the far end. We planned to change the existing 4-barrel lugs to 6-barrel to accommodate the new conductors. However, The existing neutral bus will not accept the new lugs and apparently we cant get a larger replacement. In the past I've used a polaris type tap in disconnects for the neutral. I understand i will have to bond the tap to the encloser. Am I reaching, or will this not pass inspection?
