Service Disconnect
I need some suggestion for a service disconnect between meter and main breaker panel inside. The panel is an 100 Amp Homeline Square D.
What would you suggest as an 100 Amp service disconnect outside? General fused safety switch or main breaker panel?
Thank you
IMO the first choice is a main breaker panel if it's located nearest the entry of the SEC's into the structure. Secondly would be the use of an external main breaker adjacent to the meter. I would avoid fuses for a 100 amp dwelling service.
Or if you want to keep it clean just install a meter socket with main disconnect. It's not a huge jump in price to go from 100A to 200A. Remember that if you install the disconnect you will have to remove the MBJ from the panel inside and bring your GEC to the disconnect outside where your neutral will be bonded.
The house already has a 60 amp fuse type box with lever. It is being upgraded to 100 amp. The new homeline 100 amp main breaker already in place and they want to keep some sort of disconnect outside.
Why you don't recommend the lever/fuse type?
I can t really move the meter. It is separate and part of a 3 meter box serving different unit.
Whatever your electrician prefers. I note by your profile you are a General Contractor.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
