I can't picture this. Can you send a picture?I just saw a new 600 amp service installed where they came into the building to a non fused disconnect about 7 feet from the outside wall. Then they ran about 20 feet to a 9 gang meter fitting with 100 amp breakers built in for the panel disconnects. What I'm questioning is the non fused disconnect they used. That needs to be fused, Correct?
