I dont know if my original topic posted so i will try again.
Some AHJ in our area consider the Individual Tennant breakers in a group metering system as as a seperate service and allow as many as needed to feed the load without a main disconnecting means in the Metering Tap Box. I have seen group metering with a lot more than
6 meters and tennant breakers without a Main Disconnecting means in the tap box of the group metering.They consider each individual tennant breaker
a new service. I disagree. In my mind if you have more than 6 Tennant breakers in a group metering system, you should be required to have a Main disconnecting Means in the Tap Box feeding the group metering. I consider the service entrance conductors the Wiring from the utility Xfmr to the Group Metering. Not the wiring from the Tennant Breaker to Load.
Who is correct?
Who is correct?
