The situation is this. I have a four apartment, multi-family dwelling with individual main lug only panels in each apartment. Outside the building there is a four gang meter stack up feeding the apartments with no disconnects. Was it ever the case (circa 1960 or earlier) that this was an allowable treatment for the service, that is, to clear the service you had to go to each individual apartment to open all the breakers? Or did the Code always require a service disconnect outside the building at the stackup assembly?
