Advice needed....
This question applys to a residential home. The main service an exterior surface mount overhead fed 200amp panel with distribution. The main panel feds two interor sub panels. One of which has a riser up through the roof to a weather head and an over head fed to a garage with riser etc, then overhead again to a shed with riser etc.
My question: we are replacing the conductors on the overhead feed to the garage and shed along with other work. What type of over head conductors can i use. The lenghts of the spans are 40' and 30'. The circuit size is 50amps. I have looked at Triplex. Is there another code compliant conductor? Thanks for your time.
