How do most of you typically handle calculating incident energy at the service entrance gear?
My local utility typically provides SCC and X/R at either the primary or secondary terminals of the utility transformer. They also provide the upstream fuse, which I assume is located in the cutouts at the drop (for a pad mount XFMR). What they don't usually provide is the SCC at the fuse or the primary cable info.
Do you usually calculate the incident energy at the service entrance panel by modeling up to the utility fuse? It seems that I'm lacking information if I wanted to do it that way.
In the past I've just assumed an incident energy greater than 40 cal/cm^2 and used a label stating "Exceeds Max PPE Arc Rating". More recently, I've modeled up to the XFMR primary or secondary (wherever they provided the SCC at) and assumed a fault clearing time of 2 seconds. This method likely inflates the incident energy in most cases, but it seems like a safe bet given the known utility data, and it gives you a value for IE which I think is more valuable than just knowing it's above 40.
What are your thoughts?
