NEC User
- Marlboro, NJ, USA
I have a utility pad-mount transformer located 20 feet from the building. My electrical room is not on the first floor. My service entrance conductors from the utility transformer to the Main Disconnect inside of the building are routed using RMC conduit. Once inside of the building the conduit is mostly routed within a 2" concrete slab within the walls of the building. The electrical room is located within the middle of the building. The conduit is routed from the wall/concrete slab approximately 25 feet without being encased in concrete. I'm not sure if there is a way to keep the conduit encased within concrete until it gets to the main disconnect switch which is part of the MDP. It may not be feasible to encase the service entrance conduit within concrete for this additional 25 foot run.
I'm considering recommending to install the main disconnect switch on the exterior of the building. This way the service entrance conductors are only from the utility transformer to the main disconnect installed nearby. Then I shouldn't have to worry about the conduit from the exterior main disconnect routed through the building to get to the MDP not being encased in concrete because they are no longer considered service entrance conductors.
Your thoughts?
Your thoughts?
