I need some clarification on this one.If one was changing a panel,and it was a residential 100 amp service.What happens if you change the panel and then find out that the neutral conductor passes thru and does not actually bond to the old round meter base? I also want to know if the current code allows us to splice ungrounded conductors inside the panel.It's NEC only and I have always wanted to know for myself.Thanks for your help.Ranger
