Service Entrance Connection
matt123
Hey guys, so I am looking to crimp rather than use the polaris connectors for the connection at the weather head. Does anyone use crimps and cold shrink as a method of connection? Seems like it might be quicker and more reliable than the set screw?
Here the power company makes those connections and they use crimp connections with a plastic covering over the crimped area.
When we temp the connection we use the cheapest split bolts we can find because the power company will just cut them off and use their crimps.
Like Dennis mentioned there is snap on plastic covers for those connectors.
If you want shrink, heat shrink is less costly than cold shrink though cold shrink typically has better UV resistance I believe.
Over here in NJ most of the time they do not cut and re-splice anymore. I dont usually use the plastic covers because they crack or don't stay connected so generally tape is put over. Had a few call backs because when it starts to let go people call because they see the flag or flap and think there's a problem. This is why is usually use the rubber coated polaris connectors.
Bet those same people call if the nylon jacket on THWN starts to come off as well, which I have seen happen many times.
If I'm making a temp connection, I use set-screw butt splices, then tape them. POCO replaces them sometimes
You can also buy them with plastic caps. That makes them underground splice kits
Shrink tube caps is about only thing worth using for underground splicing.
what do they call those plastic covers on the connection points? The "clamshells" is what i would always call them.
Don't think there is any specific term used across all the brands other than may just call them a cover in the catalog. Some may specify "direct burial rated" if that applies.
Those of you under the 2020 NEC , don’t forget about the requirements per 230.46.
I use these when I can :
They come in larger sizes like 4/0-2 or 4/0-4/0
I've been using this crimper :
But it certainly wasn't $450. I think I paid $150 several years ago
