A/A Fuel GTX
- WI & AZ
- Electrician
Since most of my work is of the residential type, I'd like to verify that I'm thinking correctly on this situation. I need to feed a new Panel at a business that has an 800 amp CT cabinet as part of the service equipment. My design is to come out of the bottom of the CT cabinet with an underground conduit and run about 100' on the exterior of the building and then up and into a Panel with a main breaker. I will run a GEC from the new panel to the existing GEC system and connect via a tap at that point. My line of thought here is that I can install these service entrance conductors at any length without a disconnect as long as they are outside of the building. Are my assumptions correct?
