Service Entrance Grounding
dvcraven0522!
St. Louis
Electrical Design
I have question relative to service entrance grounding conductor. If I have 400ampere fusible disconnect on a wall outside that feeds a 400ampere MLO panelboard indoors. Is the ground conductor that will feed the panel sized per NEC Table 250.66 of are the ground conductor sized per 250.122.
Thanks
Dan Craven
