I have a question on Service Entrance Grounding:
The code handbook exhibits show that the Grounding Electrode conductor should be connected to the Neutral bus and then bonded to the Ground bus. Our institution wiring right now has all grounds connected to the Ground bus and then bonded to the Neutral bus. I realize that either way is acceptable by NEC 250.30. My question is; which is the better way to ground and why?
