Re: "service entrance rated"
I know this post mainly deals with the ratings on panelboards but I work in the standby power industry and wanted to give you something to look out for if you ever deal with automatic transfer switches.
There is a huge difference between a standard ATS and a service entrance rated ATS. You typically use a standard ATS downstream from some main disconnecting means. Either a main panel, behind a main disconnect, etc. If, however, you are using an ATS to feed directly off of utility and then into a main panel (i.e. the genset will back up the entire building) then you need a S.E. rated ATS. These are typically 2-3 times the cost of a normal ATS and come in much bigger cabinets since they incorporate either a main breaker or main disconnect.
I see EC's get into trouble over this all the time. They either don't realize the cost or don't allocate enough space.
[ November 18, 2005, 03:04 PM: Message edited by: DuganC5 ]
