cvirgil467
- NewYork
Our service equipment is located on the second floor. The service entrance condcutors will be routed below the building and then turn up a shaft. Do the conduits need to be encased in 2" of concrete when routed through this shaft? The shaft will also contain other conduits for feeders and branch circuit wiring. Forget opinions for now, i just want pure code analysis.
I could not locate anything in the 2005 code that says i need to concrete encase the conduits other than if the service conductors were passing through to feed another building.
Thanks.
C
Thanks.
C
