service entrance tap box commercial appl.
hamic
is it code and what article no. to drill a hole in the back of a tap box for multi services directly in the building for grounding electrode condutor to cold water ground before the main water valve? I forgot to say also in a conduit pvc.
hamic
Tap box
Tap box
its for main service entrance conductor to a main bus tapped on either side are the service disconnects and meters, bolt down bus on either side.
hamic
bolt down bus on either side to Tennents disconnects and meters
JohnJ0906
Baltimore, MD
250.24(A)(1)
250.64(D)(3) ('08 NEC)
You are using a modular setup?
I think this is legal, as long as you are following the manufacturer's instructions, and the POCO rules.
jrannis
Can you post a pic of the project??
