service equip and transformers
mm
house of power, ... do you remember some of the questions that were asked about service equipment and transformers, there were 19 of them ?... here is a few, #1 secondary current when the pri voltage is 480 at 200amp. #2 netural and egc, where not to connect ? #3 service conductor over a 6 and 1 roof ? #4 the 24 inch exception for service conductors.#5 workspace about electrical equipment ? can you recall a few more of the questions?
mm
Re: service equip and transformers
misl questions, I can only recall 2 out of the 5. the voltage drop for the 80 ft circuit, and the netural load for the 2000 sf hall . what were the other three ?
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
Sorry my friends. But I am putting a stop to this. If the two of you wish to communicate directly with each other, then start with a Private Message, and give each other your email addresses. This forum is not intended to be used as a chat room, or a way for two members to talk directly with each other.
If you have a question for the entire membership to address, then feel free to post the question.
