Can someone point out the code section that prevents the meter base, mast, disconnect enclosure, etc... from obstructing a window?
In bidding a service upgrade job, the customer politely insisted that the new meter be attached at a 90 degree inside corner of his house. There is a window within a few inches of that corner. Imagine looking out someone's window and seeing the side of a meter and you will have an idea of what he wanted.
* The point where the conductors would emerge from the conduit is greater than 3 feet from the window.
* The window is not a bedroom window where emergency egrees codes might apply.
Thanks,
Mike
Thanks,
Mike
