Hey! I am working in Iraq and found an oddball situation. A 120/208 generator supplying 120/208 60hz to overcurrent devices, RCD's(GFCI) and receptacles that are marked 220/ 400 50hz. Does this sound right and where do I locate in the NEC? The BLS does not cover our voltage nor does ours cover their voltage... I was not comfortable with this installation considering it is in a building with an identical panel for 220/400V. It is a little confusing.
