Service feeder to 6 disconnect rule
Jpflex
Electrician big leagues
Victorville
Electrician commercial and residential
I was wondering that if you met the qualifications to allow yourself to install 6 service disconnects, then if the main building to be served were set for a 200 ampere service and you select a feeder for this, would it make sense to add 5 more service disconnect panels rated also for 200 ampere?
It seems this is how it's done but paralleling moree services may increase amps beyond the service feeder
