Service GFCI protection
ksmith846
Quick question......
3000 Amp 120/208 Volt Service does not require GFCI protection per NEC 230.95
Doesn't this Article only pertain typically to 277/480 Volt Services??
Thanks in advance to all
mcclary's electrical
VA
Are you under one of the five exemptions? Why do you say it is not required?
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
First off they are talking about GFP (ground fault protection) for equipment, not GFCI for personnel. There is a difference.
Secondly, it applies to wye services with more 150 volt to ground.... Your 3 phase 3000 amp 120/208 service is not greater than 150 volts to ground so it is not needed.
ksmith846
Thanks that is the answer to the question I was trying to ask.
