I have an inspector that claims we do not need a ground wire for the following service. The service is a residential 400 amp, 120/240 volt, single phase that has the main breaker mounted in a free standing meter/combo that feeds a 400 amp main panel located approximately 700 feet from the main and is fed with parallel 250 mcm aluminum wire in 3" pvc conduit. The inspector claims we do not need a ground wire in the pvc conduit since the neutral is the ground wire. The meter/combo has a ground rod & ufer and the main house panel has a water pipe and ufer ground. Seems a little strange to me, what do you think?
