I'm installing a new service in a house & I'm putting a disconnecting means on the outside under the meter. My first question is: Do I treat this disconnect enclosure as the service panel in regards to grounding & bonding? Do I bond the neutral block to the enclosure? Do I drive a ground rod & connect in this enclosure? Do I have to bond it to a water pipe? I know that is a lot of "first question", but here I go with some more. Since a separate ground bar isn't required at this point, can I run from the disconnect to the panel with 2 wire SE cable w/ bare neutral or do I need a 3 wire w/ ground cable? Thanks for any information.
