service gutter bonding
Seekthetruth
Florida
Electrical
A metal service gutter feeding 2 disconnects with pvc nipples with two sets of service conductors 3/0 from meter. What is the best way to bond the gutter?
Some type of lug that can be used to connect the neutrals to the gutter.
Perhaps a lay in lug (2 in this case) would be cheapest and easiest?
Probably the easiest way would be to use a #4 from each disco neutral bar back to a 2 hole lug bolted to the gutter.
I usually use this method. Only slight hiccup is NEC doesn't address SSBJ's for services with multiple enclosures. Sizing for each enclosure like s GEC tap seems logical, but is not stated.
You could even connect each end of a wire to one neutral conductor, and land the middle of it in a single lug.
Used to use stud bolt kerneys.
Neuitral insulation is removed but conductor is not cut. Eliminates a potential loose connection.
