GerryB
- woodbridge, ct. USA
The job is to install a service on a pole for security lighting. Only one 20 amp circuit is needed. Can a 100 amp meter main be put up (yes) and then the 100 amp breaker removed and replaced with a two-pole 20, then use one leg for the needed circuit? (I didn't do this but it has been suggested. My thought was just put a meter with a small (6ckt or less) box below it.
