Alwayslearningelec
- NJ
- Estimator
What is it for exactly? THis is extra cable rolled up in the ceiling? THanks.
I saw reference in another thread about fiber or cat 6 sometimes requiring a "service loop" of say 10' to be rolled up in a ceiling.:?
You remember which one or any of the posters by chance?
Ok I just used 10' as an example. What I am getting at is when a service loop is usually called for regarding LV cabling what are they usually referring to?
Because you cannot splice data cables they often require a service loop at the top of each drop.
This way there is more cable if you need to re-terminate the jacks or move the drop a bit ...... whatever 'service' may be done in the future.
Even when not required it is the professional way to do it. Of course if you have a 1000 drops (Think 250 locations four jacks each) each with a 10' loop that is 10,000' of extra cable you better plan for.
You literally leave a 10' coil of extra cable above the jack location in the ceiling, plan on a support and some straps for each of these.
Here are some examples
