service panel ground and neutral
I have a customer with an existing installation.
The sub panel has Pushmatic breakers and the neutrals and grounds are all connected to a common grounded terminal block.
The house inspector (hired by the buyers) says the neutrals must be separated from the grounds.
When I researched this it seems that he is correct, but I do not understand the difference since the ground and the neutral bars will still be connected to the ground bar in the main panel.
Do I need to install a neutral bar and if so why?
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
